Product Administration Guide > Siebel Configurator Scripts > Siebel Configurator Script Events and Methods > GetObjQuantity MethodThis method returns the quantity of the specified component product in the current solution. SyntaxGetObjQuantity (ProdName) as Integer
ItemsCan be used only for component products within the customizable product. ReturnsQuantity of the component product in the current solution as an integer. If multiple instances of the component exist, the quantity of all instances are added together and the sum is returned. For example if there are two instances of an item one with quantity five and the other with quantity three, the return is eight. ExampleThis script fragment obtains the quantity of 10 GB Drive (vendor = Sony) in the current solution and assigns it to the variable iItemQty. |
| Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
