Product Administration Guide > Siebel Configurator Scripts > Siebel Configurator Script Events and Methods > RemoveItem MethodThis method reduces the quantity of the specified item to 0 in the current solution. If multiple instances of an item have the same path, the Siebel Configurator engine randomly picks one of the instances and removes it. NOTE: This method cannot be used to remove the item that the user has selected if the selection is invalid. The best practice is to use alternative methods to prevent the user from selecting the invalid product. SyntaxRemoveItem (ObjPath) as Integer
ItemsCan be used only for component products within the customizable product. ReturnsReturns 1 if the item removal was successful. Returns 0 if the removal fails. ExampleFor an example of using RemoveItem, see About Product Path in Siebel Configurator Scripts. |
| Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
