Product Administration Guide > Smart Part Numbers for Products with Attributes >
Assigning Smart Part Numbers to a Product
Smart part numbers defined on a product class are not inherited by the products in the class. You must manually assign the part number generation method to a product. When you assign a generation method to a product, this method is used for generating part numbers whenever this product is used in new quotes, orders and so on. To assign a generation method to a product
- Navigate to the Administration - Product screen, then the Product Definitions view.
- In the Products list, select the desired product.
- In the bottom applet, in the product Part Number Method field, enter the generation method information.
- Click Release to make it take effect.
