Siebel Public Sector Guide > Managing Immigration Contacts > Adding a Contact Identity RecordBefore adding a new immigration contact, use the Immigration Contacts Home page to query for the contact. From the home page you can search for the contact by last name, first name, gender, birth date and citizenship. A new contact can only be created from the Identity list view. The Identities list view shows all identities regardless of contact. An identity record is created and saved, and a contact ID is automatically generated from the Identity. Users can then drill into the Contact ID field and add additional details such as addresses, cases, credentials, photographs, and so on. When a new identity is created for a contact, its default status is Active, and the identity defaults to the primary identity for the contact. A previous active identity is changed to inactive, and the Expired Date for the identity is populated with the current date. Users can override the defaults by updating the status, or selecting a different primary identity. On the Immigration Contacts More Info view, the contact's primary identity appears in the identity form. Users can see other identities from the same view. The colored icon in the More Info view header indicates the status of the displayed identity record. For active identities, the icon is green; for inactive identities, the icon is red. A list of all identities for a particular contact is available on the Immigration Contact Identity History view. This task is a step in Process of Managing Immigration Contacts.
| Siebel Public Sector Guide |
