Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server > Setting Siebel Remote System Preferences >
MRG: System Conflict Resolution
Siebel Remote uses one of two rules to resolve conflicting database updates:
- Client Wins. Updates from a Mobile Web Client will take precedence and overwrite those already on the server.
- Server Wins. Updates from a server will take precedence and overwrite those already on the Mobile Web Client. This is the default value.
These values are case sensitive. You should use the default setting.
