Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server > Setting Siebel Remote System PreferencesSeveral enterprise-wide preferences affect the way Siebel Remote manages database changes. During the initial implementation, you should use the System Preferences Administration view to set the system preferences. NOTE: It is important to remember that Mobile Web Clients need to be reextracted whenever there is a change to any of the system preferences settings. To determine which changes will be routed to the Mobile Web Clients, check the Dock Object Visibility Rules under the SystemPref Dock Object in Siebel Tools. For more information on Dock Objects and Visibility Rules, see Configuring Siebel eBusiness Applications. To set Siebel Remote system preferences
Table 5 lists the Siebel Remote system preferences that you may want to set. For more information about each system preference, see the related section in the following pages. |
Siebel Remote and Replication Manager Administration Guide |
