Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server >
About Virtual Memory or Swap Size for a Siebel Remote Server
Performance can be affected by the size you set for virtual memory (Windows) or swap space (UNIX) on your Siebel Remote server. For best results, it is recommended that you set the size of virtual memory or swap space to 1.5 times the size of the server's physical memory (RAM). Use standard operating system techniques to accomplish this. For example,
- In Windows 2000, the virtual memory setting is reached by navigating to My Computer > Properties > Advanced > Performance Options > Virtual Memory > Change.
- In UNIX, a typical command to set swap space size is swap. Consult the documentation for your server's operating system for confirmation that this is the correct command and for command syntax details.
