Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server > Preventing Extraction and Synchronization of Older DataThe Time Filters feature allows administrators to prevent selected kinds of older data from being sent to all Mobile Web Clients during database extraction or synchronization. By reducing the amount of data to be sent, time filtering can reduce the amount of time required for database extraction and synchronization. Time filtering may also enhance Mobile Web Client response time. Time filtering is deployed on a per dock object basis. For each supported dock object that will use time filtering, the administrator chooses a cut-off date. Data that was last modified prior to the cut-off date is not included in extractions or synchronizations. NOTE: The cut-off date specified for each dock object is a fixed date that is not dynamically adjusted. If the cut-off date is changed, Mobile Web Clients should be reextracted. If a Mobile Web Client is not reextracted after changing to a later cut-off date, that client would retain unnecessary older data in the local database. Storage of this unneeded data could affect performance. CAUTION: Before deploying time filtering in your Production environment, be sure to test it thoroughly. Make sure that your chosen cut-off dates for time filtering allow all necessary data to reach test Mobile Web Clients. Deployment of an inappropriate cut-off date can prevent stable but necessary data (such as price lists or rate lists) from reaching Mobile Web Clients. If this occurs, you must choose an earlier cut-off date and reextract the Mobile Web Clients. By default, time filtering is supported for the following dock objects:
It is possible to configure additional dock objects for time filtering. However, for many Siebel implementations, most of the benefits that time filtering provides will come from using the dock objects that are supported by default. For information about making time filtering available for additional dock objects, see Configuring New Dock Objects for Time Filtering. The following procedure describes how to set up time filtering for a supported dock object. To prevent synchronization of older data for a supported dock object
If you use time filtering but find, by experience, that your business still requires synchronization of older data, the following procedure describes how you can stop using time filtering for any supported dock object. To allow synchronization of older data for a supported dock object
Siebel Remote and Replication Manager Administration Guide |
