Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Remote and Replication Manager Administration Guide > Siebel Remote Concepts > Siebel Remote Server Components > Creating Siebel Server Directories for Mobile Web ClientsEach registered Mobile Web Client requires a separate directory on the Siebel Remote server. The Database Extract program creates the appropriate directory and its subdirectories for each Mobile Web Client. NOTE: The installation program also places a directory called txnproc in the docking subdirectory within the Siebel server root directory. Do not modify the contents of this directory under any circumstances. The following example shows a portion of the server directory tree after you run Database Extract for Mobile Web Clients named Adams and Scott: siebel |
Siebel Remote and Replication Manager Administration Guide |
