Siebel Remote and Replication Manager Administration Guide > Siebel Remote Concepts > Siebel Remote Server Components > Generate New DatabaseThe Generate New Database component creates the local database template for a given database schema version. The component reads the database schema definition from the Siebel repository, then creates Siebel tables and indexes in a database template file stored on the Siebel Remote server in the dbtempl subdirectory. The Local Database Initialization program uses the local database template when initializing a new database on the Mobile Web Client. NOTE: Dicdata.dat and diccache.dat are the same dictionary file. Dicdata.dat is named differently for Mobile Web Clients. These files store metadata about schema definitions, vis-rules, and other items. Administration of the Generate New Database ComponentYou must generate a new database template whenever the Siebel database schema changes in cases such as:
If your deployment requires a different collation template not provided by Siebel eBusiness Applications, please contact Siebel Expert Services for assistance in creating a new collation template. Optimal Size for Local DatabasesThe recommended size for the SQL Anywhere local database depends upon several factors. These include the Mobile Web Client user's position and responsibilities. Also, the Data Routing Model assigned to the client impacts the volume of data to be stored in the local database. The local database should not be larger than 700 MB. For further information on this subject, or if a local database will exceed this number, contact Siebel Systems. |
| Siebel Remote and Replication Manager Administration Guide |
