Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Replication Manager > Defining the Regional Node > Adding Mobile Users to the Regional NodeIf a regional node will support Siebel Remote mobile users, continue with the following procedure to add the mobile users to the regional node. If this regional node will support only connected users, skip this section and proceed to Extracting the Regional Database. NOTE: Every mobile user on the regional node must also be a connected user. To add mobile databases to a regional node
NOTE: A mobile user can be assigned to only one Headquarters server or Regional node. Every mobile user must also be set up as a connected user in the Regional Node. Mobile Web Clients must be synchronized and then reextracted if they are to be reassigned to a different parent server. |
Siebel Remote and Replication Manager Administration Guide |
