| Siebel Financial Services eBusiness Application Integration Guide > Overview > Details of Siebel Financial Services eAI > Cross-Application Process Integration
 		The Siebel eBusiness platform supports workflow control in order to achieve process level integration between Siebel applications and external applications. You use the Siebel Workflow Designer to define the integration processes and Siebel Workflow Engine to execute and manage integration processes.  The business services you use to build the workflow process can be a prebuilt component, such as a transport adapter and the Industry XML Dispatcher, or can be custom developed at design time or run time using one of the Siebel Scripting languages. |
