| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Financial Services eBusiness Application Integration Guide > Overview > Siebel Financial Services eAI Connectors > Siebel Connector for ACORD XMLThe Siebel Connector for ACORD XML is an enhancement of the generic Siebel Financial Services Industry XML Connector. This connector allows Siebel applications to transfer data between Siebel applications and external ACORD-based applications. It uses XML to handle data formatting and conversion according to the ACORD forum standard. The Siebel Connector for ACORD XML provides integration between Siebel eBusiness Applications and other insurance application systems, such as a policy administration system that implements the ACORD XML standard. The connector supports the ACORD XML Business Message Specification for P&C Insurance and Surety, an insurance industry standard XML specification. The Siebel Connector for ACORD XML receives, parses, and processes the business operations specified in the XML message for both outbound and inbound integrations. This integration solution offers powerful capabilities designed to meet all Property and Casualty message specification requirements. This solution also allows you to effectively harness the synergies between Siebel front office applications and ACORD-based applications. The Siebel Connector for ACORD XML allows Siebel applications to integrate with back office data and business processes for both synchronous and asynchronous transactions across applications. NOTE: For details, see Siebel Financial Services Connector for ACORD P&C and Surety Guide. |
| Siebel Financial Services eBusiness Application Integration Guide |
