| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Financial Services eBusiness Application Integration Guide > Financial Services eAI Business Scenarios > Data Access and ReplicationAt times, you may need access to some specific data to accomplish a given task. Often it is not sufficient to bring everything to the same screen. Many business processes require access to particular data in order to accomplish a given task. This section describes the following four examples: |
| Siebel Financial Services eBusiness Application Integration Guide |
