Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Uninstalling Siebel Applications > Uninstalling Siebel ClientsTo uninstall Siebel application client software (Siebel Mobile Web Client, Siebel Developer Web Client, or Siebel Sample Database) on Windows systems, run the Siebel Systems Uninstallation Manager from the Windows Add or Remove Programs panel. Any file that is updated by a user after installation is not deleted. After uninstallation, files remaining in the client installation directory can be safely deleted at the discretion of the administrator. NOTE: If you installed the Siebel Sample Database, you must uninstall it separately before you uninstall the Siebel client where you installed the Sample Database. Otherwise you will be unable to uninstall the Sample Database. |
| Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools |
