Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Web Server Extension > Installing the Web ServerBefore installing the SWSE, you need to install, configure, and start the supported Web server software on the designated machine. For the best performance and scalability, put the Web server on a dedicated machine. SWSE Installation Directory PermissionsMake sure that the user running the SWSE plug-in has read, write, and execute permissions on the SWSE_ROOT directory and its subdirectories (where SWSE_ROOT is the directory in which the SWSE is installed). On Windows, you must grant these permissions to the IWAM and IUSR user accounts. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
