Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing Siebel Mobile Web Clients > Postinstallation Tasks for the Siebel Client > Verifying ODBC Data Sources for the Siebel Mobile Web Client and Developer Web ClientBased on settings defined in the siebel.ini file for the Siebel client, the client installer creates the ODBC data sources shown in Table 16. By default, these are created as user data sources, which are visible only to the user account under which the Siebel client is installed. If two or more users need to log in using the same Windows client machine, install the client using the For each data source name, an optional DSN suffix may be defined to allow multiple DSN instances to be referenced from the siebel.ini file. This is required if you will install multiple instances of the Siebel software on the same machine, each of which will access a different data source. In the data sources shown in Table 16, the DSN suffix is represented as optional_DSN_suffix. In the siebel.ini file, the suffix is specified using the parameter In Table 16, another optional string, the DSN prefix, is represented as optional_DSN_prefix. The DSN prefix comes before the DSN suffix. The ODBC data sources for the Sample Database and the local database use the values Samp Db and Local Db, respectively. For more information about creating custom client installer packages using the Packager utility, see Going Live with Siebel Business Applications. NOTE: Make sure to use the ODBC drivers described in System Requirements and Supported Platforms on Siebel SupportWeb. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
