Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Server > Verifying the ODBC Data Source for OracleThe Siebel Server installation program automatically creates an ODBC system data source name (DSN) that it uses to connect to the Siebel Database on the RDBMS. Prior to verifying the Siebel Server ODBC data source, make sure that the Siebel Server service is started. CAUTION: In general, do not change the default settings created automatically with the ODBC data source. However, if you have upgraded from Oracle 8i to either Oracle 9i or 10g, or if you manually created your ODBC, it is critical that you check your ODBC settings, as shown in the following procedure. For more information about the ODBC data source, see Planning RDBMS Installation and Configuration. To verify the ODBC data source for Oracle on Windows
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
