Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Server > Troubleshooting Siebel Server InstallationInstallation problems can be caused by a number of things, but the reasons listed in the following section are the most common:
Problem: The following error messages occur in an Enterprise supported by an MS SQL Server database: Solution: You used brackets in the name you gave to one or more of your Siebel Servers or to your Siebel Enterprise Server. Uninstall these and reinstall them, giving them a new name. Problem: The Siebel Server does not start after configuration. Solution a: Verify that the Siebel Gateway Name Server was started. Start it if it was stopped. Solution b: Verify that the values input during configuration were valid. Solution c: Verify that you have sufficient system privileges to start the service. For more information, see Creating the Siebel Service Owner Account. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
