Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Server > Siebel Server Installation RequirementsReview the following requirements for Siebel Server installation: CAUTION: Do not install Siebel Business Applications without first reviewing System Requirements and Supported Platforms on Siebel SupportWeb.
Clustering Requirements for the Siebel ServerThe Siebel installer allows you to install all servers at once for which you have a license. If you will be operating certain servers as part of a cluster, you must install and configure the Siebel Gateway Name Server and the Siebel Server on separate resource groups. For information about clustering, see the Deployment Planning Guide. Language and Locale RequirementsMake sure you have the appropriate locales on the machines on which you intend to deploy Siebel Server. Siebel log and configuration files use UTF-8 with Byte Order Mark as the default encoding. If these files contain any non-ASCII characters, proper viewing and editing requires a UTF-8 locale. For more information on supported locales, see System Requirements and Supported Platforms on Siebel SupportWeb. The language locale can affect how time is displayed. For more information, see the Global Deployment Guide. Guidelines for Installing Multiple Language Packs on the Siebel ServerIf you will be installing multiple language versions of Siebel Business Applications on your Siebel Servers, review the following configuration guidelines:
Adding a New Product to an Existing InstallationWhen you add a new product to an existing installation, it is vital that you install the same set of languages for the new product. For example, do this when adding a Siebel Server to the same directory in which you have installed a Siebel Gateway Name Server. All Siebel Enterprise components must be at the same release and patch level. Siebel SearchA Siebel Server can be configured to execute searching or can be pointed to another remote Siebel Search server to handle search execution tasks. If you want a server to function as a Siebel Search server, you must install the Siebel Search server (Hummingbird SearchServer) before installing Siebel Server on that machine. For more information about Siebel Search, see the Siebel Search Administration Guide. Database RequirementsMake sure your database administrator has installed the RDBMS your site will be using. During installation of the Siebel Server, you must have an established connection to that database for installation to be successful. For more information, see Configuring the RDBMS. The RDBMS you are using must support the same languages and code pages that you will install on the Siebel Servers. To see the code pages and languages supported both for Siebel Servers and the RDBMS, refer to System Requirements and Supported Platforms on Siebel SupportWeb. Third-Party Software RequirementsMake sure that you have already installed the appropriate version of all third-party software products required. Otherwise, the Required Software Components prompt appears. For more information, see System Requirements and Supported Platforms on Siebel SupportWeb. Temporary Disk SpaceReview the issues described in Managing Temporary Disk Space Required by Installers. For example, make sure you have adequate disk space. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
