Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Preparing for Installation > General Considerations in Planning Your Siebel Deployment > Managing Temporary Disk Space Required by InstallersSiebel installer programs for server-based software require the use of temporary disk space during installation. Disk space required varies by platform. The location of temporary directories is specified using the CAUTION: Temporary directory names must not include spaces, in order to avoid problems associated with the operating system returning a long path name when a short path name is requested. Installers may fail if this problem is encountered. Alternatively, when you run a Siebel installer program for server-based software, you can specify which temporary directory the installer should use in place of the directory specified by setup.exe -is:tempdir For more information about command-line options for Siebel installers, see Additional Flags for Installation Commands. Table 3 shows the minimum disk space required by Siebel installers for server-based software (by platform), along with the default temporary directory locations. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
