Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Server > Starting the Siebel Server ServicesIf you did not select automatic Siebel Server start-up, you must start the Siebel Server services manually after you finish installation of the Siebel Server. If you will be clustering a particular server, you must start and stop it using the Cluster Administrator, rather than with the following procedure. This procedure is not necessary if you selected automatic start-up during configuration. To manually start the Siebel Server service
Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
