Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing in Unattended and Console Modes > Installing in Unattended Mode > Running the Installation from the Command LineAfter you have modified the appropriate siebel.ini files in the previous procedure, run the unattended installation from the command line. However, before running an unattended installation, be aware of the following guidelines:
NOTE: These instructions are for installing the Siebel Enterprise Server using unattended mode. Installation in unattended mode of other server products is similar. CAUTION: When using Terminal Services on Microsoft Windows 2003 to perform an unattended installation, make sure you set the mode to installation. Otherwise, the install process will not create the Siebel ODBC data source name (DSN) and you will not be able to bring the server up.
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
