Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing in Unattended and Console Modes > Installing in Unattended Mode >
Installing Siebel Reports Server in Unattended Mode
This section provides instructions for installing Reports Server in unattended mode. For detailed information about modifying siebel.ini files, see Editing siebel.ini Files for Unattended Installation. (Do not modify settings in RunAfter sections.) NOTE: For more information about installing Reports Server, see Installing the Siebel Reports Server. In particular, review the information presented in Preinstallation Tasks for the Siebel Reports Server.
Before starting the Reports Server installation, you must modify portions of the siebel.ini file, as described in the following section. After you are done with the installation, you can perform configuration in GUI mode as described later on in this chapter. NOTE: After Siebel Reports Server is installed in the unattended mode, the Actuate iServer may fail to start. If you encounter such a problem, most likely the locale and time zone are incorrectly defined. When you install Siebel Reports Server in unattended mode, use values in the locale.txt and timezone.txt files to correctly set the Locale and TimeZone parameters in the siebel.ini file. For more information, see Table 12.
To modify the siebel.ini file for the Siebel Reports main installer
- Using a text editor, modify the siebel.ini file for the Siebel Reports Server.
NOTE: Make a copy of each siebel.ini file you plan to modify, and save it in a unique location that identifies the module it pertains to. Preserve these copies in case you may need them for later reference.
- In the siebel.ini file, locate the
[Dialog] section and set all keys to no, except the ones beginning with Uninst, to disable all prompts.
- Locate the
[Defaults] section and specify the installation location for RootDirectory, if you are installing in a location other than the default (C:\sea_thirdparty_782).
- Locate the
[Defaults.ProductSelection] section, and set those products you want to install to yes.
- Locate the
[Dialog.ActuateServer.Windows] section.
Using the following as an example, change the values to reflect your configuration requirements:
[Dialog.ActuateServer.Windows] Readme = no LocaleTimeZone = no ServiceProfile = no PMDHostPort = no iServerHostPort = no EncyclopediaVolume = no AutoStart = no AdminPassword = no MgmtConsoleHTTPPort = no
- Locate the
[Defaults.ActuateServer.Windows] section.
[Defaults.ActuateServer.Windows] ActuateLicenseKey = license_key Locale = English (United States) TimeZone = Pacific Standard Time (GMT-8:00 Pacific Standard Time) AutoStartPMD = 1 AutoStartiServer = 1 ActuateUser = hq\jsmith ActuateUserPassword = abc123 PMDHost = machine_name PMDPort = 8100 iServerHost = machine_name iServerPort = 8000 EncyclopediaVolume = volume_name AdminPassword = MgmtConsoleHTTPPort = 8900
- Locate the
[Dialog.ActuatePortal.Windows] section.
[Dialog.ActuateActivePortal.Windows] License = no HTTPDestination = no LocaleTimeZone = no HTTPPort = no HTTPServiceAccount = no EncyclopediaVolume = no iServerHostPort = no PMDHostPort = no
- Locate the
[Defaults.ActuateActivePortal.Windows] section.
[Defaults.ActuateActivePortal.Windows] HTTPDestination = C:\Program Files\Common Files\Actuate\7.0 Locale = English (United States) TimeZone = Pacific Standard Time (GMT-8:00 Pacific Standard Time) HTTPPort = 8700 HTTPServiceUser = hq\jsmith HTTPServicePassword = abc123 EncyclopediaVolume = volume_name iServerHost = machine_name iServerPort = 8000 PMDHost = machine_name PMDPort = 8100
If you are installing iServer in the same installation, the following parameters should have the same values as in [Defaults.ActuateServer.Windows]:
Locale TimeZone EncyclopediaVolume iServerHost iServerPort PMDHost
Table 12 displays the Reports Server component keys in the siebel.ini file. It also indicates whether the keys are always required and the conditions in which keys may be required. If a key is required, then there must be a corresponding value in the siebel.ini file.
Table 12. Reports Server Component Keys
ActuateLicenseKey
Y |
Specify the license key for your Siebel Reports products. |
Locale
Y |
Specify the full name of the locale you require. Include all applicable spaces. NOTE: For locale mappings, see the file locale.txt. This file is located in the directory Server\Siebel_Reports_Server, which is part of the Siebel image from which you installed the Siebel applications.
TimeZone
Y |
Specify the full name of the time zone you require. Include all applicable spaces. NOTE: For time zone mappings, see the file timezone.txt. This file is located in the directory Server\Siebel_Reports_Server, which is part of the Siebel image from which you installed the Siebel applications.
AutoStartPMD
Y |
If installing iServer and Management Console. 1 = Automatically start Process Management Daemon when Windows boots. 0 = Not automatically start Process Management Daemon when Windows boots. |
AutoStartiServer
Y |
If installing iServer and Management Console. 1 = Automatically start iServer when Process Management Daemon starts. 0 = Not automatically start iServer when Process Management Daemon starts. |
ActuateUser
Y |
If installing iServer and Management Console. |
ActuateUserPassword
Y |
PMDHost
Y |
PMDPort
Y |
iServerHost
Y |
iServerPort
Y |
EncyclopediaVolume
Y |
AdminPassword
N |
MgmtConsoleHTTPPort
Y |
HTTPDestination
Y |
If installing ActivePortal. |
HTTPPort
Y |
HTTPServiceUser
Y |
HTTPServicePassword
Y |
