Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing in Unattended and Console Modes > Installing in Console Mode > Editing siebel.ini Files for Console Mode InstallationBefore starting the installation, you must disable portions of the siebel.ini file. After you finish the installation, launch the Siebel Software Configuration Wizard through the icons created in your Start menu by the installer. For instructions on how to launch the Configuration Wizard, see Launching the Siebel Software Configuration Wizard. To modify siebel.ini files for console mode installation
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
