Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing in Unattended and Console Modes > Installing in Console Mode >
Installing Siebel Applications in Console Mode
The following procedures describe the installation of the Siebel application in console mode. To install in console mode
- From a DOS prompt, navigate to the Siebel image directory for the current software version. Then navigate to the directory where the main installer is located.
For example, navigate to Siebel_Image\Windows\Server\Siebel_Enterprise_Server.
where:
- Siebel_Image = The directory for your version-specific Siebel network image, such as D:\Siebel_Install_Image\7.8.2.0.
- Execute the following command:
setup.exe -is:javaconsole -console -args SS_SETUP_INI=main_installer_siebel.ini_path
where:
- main_installer_siebel.ini_path = The full path to the main installer siebel.ini file.
NOTE: There should be no spaces before and after the equals sign in the command.
For example, you might enter:
setup.exe -is:javaconsole -console -args SS_SETUP_INI=D:\Siebel_Install_Image\7.8.2.0\Windows\Server\ Siebel_Enterprise_Server\siebel.ini
The console mode installation script appears. For more information about specific prompts, see the module-specific installation chapters in this guide.
- Launch the configuration in GUI mode. See subsequent chapters in this guide.
