Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring MS SQL Server for Siebel Applications > Guidelines for Overriding MS SQL Server Default Table Spaces for Database ObjectsSiebel Systems provides the option of overriding the default storage parameters for the table spaces you create to hold specific tables or indexes. To do this, edit the ddl.ctl file located in the dbsrvr\MSSQL directory. NOTE: The ddl.ctl file should be modified only by a qualified DBA. For each Siebel table, you can specify a table space by using the As shown in the example that follows, you can use the [Object 219] For an example of overriding the defaults for specific tables and indexes, see Guidelines for Overriding DB2 UDB Default Table Spaces for Database Objects. |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
