Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring IBM DB2 UDB for Siebel Applications >
Guidelines for Setting DB2 UDB Database Manager Configuration Parameters
You can set the database configuration parameters using the update database manager configuration command of the DB2 Command Line Processor or using the DB2 Control Center. For more information on modifying these configuration parameters, see the IBM DB2 UDB technical documentation. Table 5 describes DB2 UDB database manager configuration parameters that differ from the default settings. Set these parameters for each DB2 UDB instance. Use the configuration information in Table 5 for the listed parameters. For parameters not listed in this table, accept the default settings.
Table 5. DB2 UDB Database Manager Configuration Parameters
SHEAPTHRES
Sort heap threshold (4 KB) |
200000
Deployments with 3,000 or more concurrent users and using over 5 GB of RAM can increase this to 300000. |
DIR_CACHE
Directory cache support |
YES
ASLHEAPSZ
Application support layer heap size |
15
RQRIOBLK
Maximum requester I/O block size (bytes) |
65535
MON_HEAP_SZ
Database monitor heap size (4 KB) |
128 (minimum)
QUERY_HEAP_SZ
Query heap size (4 KB) |
16384
KEEPFENCED
Keep Fenced process |
YES
MAXAGENTS
Maximum number existing agents |
20000 (minimum)
NUM_INITAGENTS
Initial number agents in pool |
10
NUM_POOLAGENTS
Number of agents in the agent pool kept active at all times |
80
MAX_COORDAGENTS
Maximum number coordinating agents |
MAXAGENTS
INDEXREC
Index re-creation time |
RESTART
INTRA_PARALLEL
Enable intra-partition parallelism |
NO
DB2set Parameters
Use the db2set command to set the parameters (for example, db2set DB2_HASH_JOIN = NO) referenced in Table 6. Under Windows, you access this command through the DB2 Command Line Processor.
Table 6. db2set Parameters
DB2_HASH_JOIN
Turns off hash joins in the optimizer. |
NO |
DB2_CORRELATED_PREDICATES
When set to YES, the optimizer is able to determine whether predicates in a query are related, which permits DB2 to calculate the filter factor more accurately. |
YES |
DB2_PIPELINED_PLANS
Tells the DB2 optimizer to favor pipeline execution plans—plans that are left deep and have no temporary result sets. |
ON |
DB2_INTERESTING_KEYS
Limits the number of execution plans generated by the DB2 optimizer. |
ON |
DB2_PARALLEL_IO
Useful when using RAID devices. For more information, see your DB2 vendor documentation. |
DB2_STRIPED_CONTAINERS
ON |
DB2_NO_PKG_LOCK
To bind the Siebel package with siebbind, this package must be off. |
OFF |
