Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel System Administration Guide > Configuring Siebel Servers > Configuring the Siebel Server > About Enabling and Disabling Siebel Server ComponentsWhen a component is enabled inside a component group, it is automatically assigned to all Siebel Servers configured to use its component group. The state of assigned server components appear in the Status field of the server component record. Server components have one of two possible enable states:
Disabling a server component results in:
You can only disable server components at the Siebel Server level. Disable server components within a component group on a particular server if the server component is not planned for immediate deployment but may be deployed in the future. See the following topics for procedures on enabling and disabling server components on the Siebel Server: NOTE: Disable server components that are not intended to operate on that Siebel Server to reduce unnecessary consumption of server resources. |
Siebel System Administration Guide |
