Siebel System Administration Guide > Configuring Siebel Servers > Process for Creating a Custom Siebel Server Component >
Deleting a Siebel Server Component Definition
This topic describes the procedure for deleting a Siebel Server component definition. For further information on component definitions, see About Siebel Server Component Definitions. CAUTION: Make sure no active server components use the component definition you want to delete. If in doubt, disable the component definition rather than deleting. For information on this task, see Disabling a Siebel Server Component Definition.
To delete a Siebel Server component definition
- From the application-level menu, choose Navigation > Site Map > Administration - Server Configuration.
- Click the Component Definitions view tab.
- In the Component Definitions list, select the component definition of interest.
- Click the Delete button.
