Siebel System Administration Guide > Configuring Siebel Servers > About Siebel System Parameters >
About Parameter Availability Status
The Server Manager GUI provides parameter availability status for system parameters at the following levels: enterprise, component definition, server, component, task, and session. Certain parameters become available or effective only after specific Siebel Server operations are performed. Review this parameter view to determine the necessary action to make your parameter change effective.
Table 16. Parameter Availability Status Options
Immediately |
These parameters are effective immediately and require no further Siebel Server operations. |
At Next Task |
These parameters are effective at the start of the next task. For further information on starting component tasks, see Administering Component Jobs. |
At Component Restart |
These parameters require a restart of the server component before they become effective. For further information on stopping and starting server components, see Administering Siebel Server Components. |
At Server Restart |
These parameters require a restart of the Siebel Server before they become effective. For further information on stopping and starting Siebel Servers, see Administering Siebel Servers. |
Require Reconfiguration |
These parameters require component reconfiguration before they become effective. For further information on component reconfiguration, see Reconfiguring Siebel Server Component Definitions. |
The list of parameter availability options appears in Table 16. For example, the server component parameter Maximum Tasks (alias MaxTasks) requires a Siebel Server restart before a parameter change becomes effective. See Figure 3 for an example of the MaxTasks parameter's availability status.
Figure 3. Parameter Availability Status of MaxTasks
