Siebel System Administration Guide > Application Object Manager Administration > About Siebel Application Object Manager Parameters >
About AOM Parameters in the Configuration File
Each application's configuration file contains a detailed set of parameters specific to the Application Object Manager (AOM). This file is installed as part of the Siebel Server installation, and can be modified by the system administrator. If the configuration file is modified, the affected AOM component should be restarted or reconfigured. Configuration files contain only specific sections that are used by the Siebel Server. The AOM only reads parameters from the Siebel Web Engine (SWE) section. Other sections are used only by the clients. For a description of parameters used in configuration files, see Parameters in Configuration File. For a list of configuration files, see Siebel Application Configuration Files.
