Siebel System Administration Guide > Application Object Manager Administration > Administering the Siebel Application Object ManagerYou can monitor Siebel Application Object Managers (AOM) at:
For further information on monitoring the AOM server component, see System Monitoring and Diagnostics Guide for Siebel Business Applications. At each of these levels, you can:
At the component event level, you can enable SQL tracing to view the SQL that is generated for the selected AOM. You can enable SQL spooling on the object manager task by setting the Object Manager SQL Log event parameter to 4 at the component event level. For further details on event logging, see System Monitoring and Diagnostics Guide for Siebel Business Applications. |
| Siebel System Administration Guide |
