Siebel System Administration Guide > Configuring the System Architecture > Configuring the Siebel Server and Its ComponentsBefore starting the Siebel Server, you may want to modify Siebel Server configuration. You may need to enable component groups on the Siebel Server. In some cases, you may need to reinstall the Siebel Server. This topic describes some configurations that you may need to perform after completing the Siebel installation. For details on configuring Siebel Servers and server components using the Server Manager GUI, see Configuring Siebel Servers. For details on configuring Siebel Servers and server components using the Server Manager command-line interface, see Using the Siebel Server Manager Command-Line Interface. NOTE: The instructions in this chapter assume that you have successfully installed and configured your Siebel Gateway Name Server, Siebel Enterprise Server, and other Siebel Servers. For more information, see the Siebel Installation Guide for the operating system you are using. Before starting the Siebel Server, you may want to add site-specific parameter values or overrides of existing values using the Server Manager GUI. You can configure a Siebel Server by modifying the parameters at the Siebel Server, component, or task level for the given Siebel Server. Changes to parameters at the Siebel Server level are inherited at the component and task levels. Changes to parameters at the component level are inherited at the task level. For more information, see About Siebel System Parameters. |
| Siebel System Administration Guide |
