Siebel System Administration Guide > Configuring the System Architecture >
Configuring System Environment Variables
This topic describes the task of configuring system environment variables on Windows and on UNIX. For background information on Siebel-specific environment variables, see About System Environment Variables. To configure an environment variable on Windows
- Choose Start > Settings > Control Panel > System.
- Click the Advanced tab, then click Environment Variables.
- In the System variables section, click New to create a new environment variable.
For a selection of Siebel environment variables, see Table 7.
- Set the Variable name field to the name of a Siebel environment variable.
- Set the Variable value field to the value for the Siebel environment variable.
- Restart the machine for the environment variables to take effect.
To configure an environment variable on UNIX
- Log in as the Siebel Service owner user.
- Run the
siebenv.sh or siebenv.csh script to set Siebel environment variables. For more information on these scripts, refer to the Siebel Installation Guide: Servers, Mobile Web Clients, and Tools for UNIX.
- Enter the following command to set the environment variable:
setenv Siebel_Environment_Variable Variable_Value
where:
Siebel_Environment_Variable = A Siebel-specific environment variable. For a selection of Siebel environment variables, see Table 7.
Variable_Value = The setting for the environment variable.
For example:
setenv SIEBEL_SARMLevel 1
Environment variables are variables configured for a particular machine hosting an aspect of a Siebel deployment. These Siebel-specific environment variables configure interactions with the machine's operating system and various functions of Siebel applications. Configure environment variables through the operating system of the individual machine. See Configuring System Environment Variables for details on configuring these variables. Environment variables configure a wide-range of functionality and are covered in context-specific areas of the Siebel Bookshelf. See Table 7 for a partial listing of Siebel environment variables and where the variable is documented. This list is not comprehensive.
Table 7. Listing of Siebel Environment Variables
SIEBEL_SARMLevel |
Performance Tuning Guide |
SIEBEL_SARMBufferSize |
SIEBEL_SARMPeriod |
SIEBEL_SARMMaxFiles |
SIEBEL_SARMFileSize |
SIEBEL_LOG_EVENTS |
System Monitoring and Diagnostics Guide for Siebel Business Applications |
SIEBEL_LOG_ARCHIVES |
SIEBEL_LOG_DIR |
SIEBEL_CRASH_HANDLER |
SIEBEL_OSD_LATCH |
SIEBEL_OSD_NLATCH |
TEMP |
Siebel Installation Guide for the operating system you are using |
TMP |
Siebel Installation Guide for the operating system you are using. |
SIEBEL_SESSMGR_TRACE |
SIEBEL_SISNAPI_TRACE |
SIEBEL_STDERROUT |
SIEBEL_ASSERT_MODE |
