Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands >
Component Management Commands
Use component management commands to start, shut down, set online, set offline, enable, or disable Siebel Server components.
To start a Siebel Server component
  • Enter:
    startup component component_alias_name for server siebel_server_name
To shut down a Siebel Server component
  • Enter:
    shutdown component component_alias_name for server siebel_server_name
To set a Siebel Server component online
  • Enter:
    online component component_alias_name for server siebel_server_name
To set a Siebel Server component offline
  • Enter:
    offline component component_alias_name for server siebel_server_name
To enable a Siebel Server component
  • Enter:
    enable compdef component_alias_name for server siebel_server_name
To disable a Siebel Server component
  • Enter:
    disable comp component_alias_name for server siebel_server_name
    NOTE:  If you disable a Siebel Server component using this command, the component does not appear in the Server Manager GUI. That is, you can only reenable the server component from the command-line interface.
