Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands > Reconfiguring Component Definition CommandsTo reconfigure component definitions, you must start the component reconfiguration, make the necessary configurations (for parameter configuration, see Parameter Management Commands), and then commit the reconfiguration. See the following procedures for these commands. CAUTION: Make sure you review the background information on component definition reconfiguration before undertaking this task. See the following topic for this information: Reconfiguring Siebel Server Component Definitions. To start a component definition reconfiguration |
| Siebel System Administration Guide |
