Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands >
List Command Configuration
The following commands modify or configure the output for the list commands described in List Commands. To modify the output of an individual list command
- To display specific columns, enter:
list list_object show column_1, column_2, ..., column_n
For example:
list components show SV_NAME, CC_ALIAS
- To display specific columns with a for clause, enter:
list list_object for for_object show column_1, column_2, ..., column_n
For example:
list components for SRVR_1 show CC_ALIAS
To list available columns for a list command
To configure the output of the list command
- To display only specific columns, enter:
configure list list_object show column_1, column_2, ..., column_n
This command changes future list list_object commands to display only those columns defined.
NOTE: Once you configure a specific list command for a given srvrmgr session, it cannot be configured again in that session. A new session must be started to view other columns for that list command.
