Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands >
List Commands
Use the List command to display current data only; this command does not change any data. To list available Siebel Servers
To list component groups
If connected to the Siebel Server, the list commands list only component groups from shared memory; otherwise it lists the component groups assigned to that Siebel Server from the Siebel Gateway Name Server. See also the describe command, To list component groups from the Siebel Gateway Name Server. To list current component group status
To list current component status
- For all components, enter:
list component
- For all instances of the component, enter:
list component component_alias_name
- For a particular Siebel Server, enter:
list component for server siebel_server_name
- For a particular task, enter:
list component for task task_number
To list values for a particular task, you first need to set the current working Siebel Server by using the set server command. For information on this command, see Siebel Server Manager Environment Commands.
To list subsystems
- For all subsystems, enter:
list subsystem
To list named subsystems
To list the status of current tasks
- For all tasks, enter:
list tasks
list tasks for server siebel_server_name
- For a particular component, enter:
list tasks for component component_alias_name
- For a particular component group, enter:
list tasks for component group component_group_alias_name
list task task_number
NOTE: The number of tasks returned is determined by the Maximum Tasks parameter for that component. For more information on the Maximum Tasks parameter, see Parameters.
To list tasks for session mode components
list sessions for server siebel_server_name
list sessions for comp component_alias_name
- For a particular object manager login, enter:
list sessions for login object_manager_login
- For a list of hung tasks, enter:
list hung sessions for server siebel_server_name [or] comp component_alias_name [or] login object_manager_login
- For a list of active tasks, enter:
list active sessions for server siebel_server_name [or]comp component_alias_name [or] login object_manager_login
To list current parameter values
- For the Siebel Enterprise Server, enter:
list ent param
- For all Siebel Servers, enter:
list parameters
list parameters for server siebel_server_name
- For a particular component on all Siebel Servers, enter:
list parameters for component component_alias_name
- For a particular component on a particular Siebel Server, enter:
list parameters for component component_alias_name server siebel_server_name
list parameters for task task_number server siebel_server_name
To list current advanced parameter values
To list current state values
- For all state values, enter:
list state values
list state values for server siebel_server_name
list state values for task task_number
NOTE: To list values for a particular task, you first need to set the current working Siebel Server by using the set server command. For information on this command, see Siebel Server Manager Environment Commands.
To list current statistic values
- For all statistics, enter:
list statistics
list statistics for server siebel_server_name
list statistics for component component_alias_name
list statistics for task task_number
