Testing Siebel Business Applications > Automating Functional Tests > Using Siebel Test Automation for Functional TestingSiebel Test Automation objects support the automation of functional tests on the following types of Siebel applications: You can use a third-party test automation tool to write, record, and run test scripts on these types of applications. When using a third-party tool, refer to the documentation that accompanies the test tool for information about the specific features and functionality that it provides. NOTE: The Siebel Test Automation framework does not provide generalized automation services; it is only supported for test automation. Before attempting to use Siebel Test Automation to automate functional tests, make sure your environment is set up as described in Setting Up Your Functional Testing Environment. |
| Testing Siebel Business Applications |
