Testing Siebel Business Applications > Functional Test Object Reference > SiebApplication ObjectThe SiebApplication object provides methods and properties that allow you to manipulate an application in a test automation environment. ParentNot applicable. The SiebApplication object is the top-level object in the Siebel Test Automation hierarchy. TypeThe SiebApplication object is a container object that is one of the Application Hierarchy Objects. EventsThe SiebApplication object has the following events.
MethodsThe following methods are available from the SiebApplication object:
For a description of these methods, see SiebApplication Methods. PropertiesThe SiebApplication object has the following properties.
| Testing Siebel Business Applications |
