Testing Siebel Business Applications > Functional Test Object Reference > Functional Test Automation Objects for High Interactivity Siebel ApplicationsYou can use the functional test automation objects described in this section to write test scripts in your test tool that test Siebel high-interactivity applications. Each of these objects corresponds to a functional component in the user interface of a Siebel application. The following objects are categorized by the logical type of object they represent, and the topics that describe the objects are organized alphabetically in this reference. Additionally, each object is one of the following functional types:
The description for each object in this reference indicates the functional type of the object. Some objects can be more than one type. For example, SiebThreadbar is both a multivalue object and a singleton object, because it contains a group of data values and can have only one instance in a given context. Each object provides events, properties, and methods that allow you to manipulate the object in a test automation environment. Events represent user actions that can be recorded with a functional test automation tool. Properties are object-specific settings that indicate the state of the object. Methods are object behaviors that can be used in test scripts, but cannot be recorded using a test tool. Application Hierarchy ObjectsThese objects represent the layers of the application hierarchy in Siebel Applications: System ObjectsThese objects represent system-level controls that appear in Siebel Applications: Navigation ObjectsThese objects represent navigational elements that appear in Siebel Applications: Core Control ObjectsThese objects represent simple controls that appear in Siebel Applications: Complex Control ObjectsThese objects represent complex controls that appear in Siebel Applications:
Custom Control ObjectsThese objects represent custom controls that appear in Siebel Applications: |
| Testing Siebel Business Applications |
