Testing Siebel Business Applications > Functional Test Object Reference > SiebApplet ObjectThe SiebApplet object provides methods and properties that allow you to manipulate an applet in a test automation environment. ParentThe SiebApplet object is a child of the SiebView Object. TypeThe SiebApplet object is a container object that is one of the Application Hierarchy Objects. EventsThere are no events associated with the SiebApplet object. MethodsThe following methods are available from the SiebApplet object:
For a description of these methods, see SiebApplet Methods. PropertiesThe SiebApplet object has the following properties.
| Testing Siebel Business Applications |
