Testing Siebel Business Applications > Functional Test Object Reference >
SiebScreenViews Object
The SiebScreenViews object provides methods and properties that allow you to manipulate a screen view in a test automation environment. Parent
The SiebScreenViews object is a child of the SiebScreen Object. Type
The SiebScreenViews object is a singleton collection object that is one of the Navigation Objects. Events
The SiebScreenViews object has the following event.
Goto (ViewName, Level) |
Navigates to a screen view. ViewName is a String that specifies the name of the screen view; Level is a String that specifies its level (L2, L3, or L4). |
Methods
The following methods are available from the SiebScreenViews object:
For a description of these methods, see SiebScreenViews Methods. Properties
The SiebScreenViews object has the following properties.
ActiveView |
String |
Indicates the RepositoryName of the active Screen View. |
ClassName = "SiebScreenViews" |
Const String |
See Common Test Automation Object Properties for a description of this property. |
L2Count |
Integer |
Indicates the number of second-level screen views on the current screen. |
L3Count |
Integer |
Indicates the number of third-level screen views on the current screen. |
L4Count |
Integer |
Indicates the number of fourth-level screen views on the current screen. |
RepositoryName = "SiebScreenViews" |
Const String |
UIName = "ScreenViews" |
Const String |
