Testing Siebel Business Applications > Functional Test Object Reference > SiebPicklist ObjectThe SiebPicklist object provides methods and properties that allow you to manipulate a picklist in a test automation environment. ParentThe SiebPicklist object is a child of the SiebApplet Object and the SiebList Object. TypeThe SiebPicklist object is a multivalue object that is one of the Core Control Objects. EventsThe SiebPicklist object has the following events. MethodsThe following methods are available from the SiebPicklist object: For a description of these methods, see SiebPicklist Methods. PropertiesThe SiebPicklist object has the following properties.
| Testing Siebel Business Applications |
