Testing Siebel Business Applications > Functional Test Object Reference >
SiebCommunicationsToolbar Object
The SiebCommunicationsToolbar object provides methods and properties that allow you to manipulate the communications toolbar in a test automation environment.
Parent
The SiebCommunicationsToolbar object is a child of the SiebApplication Object.
Type
The SiebCommunicationsToolbar object is one of the Custom Control Objects.
Events
The SiebCommunicationsToolbar object has the following events.
Event Name
Description
Click (ButtonName)
Clicks a button. ButtonName is a String that specifies the RepositoryName of the button.
SelectWorkItem (ItemName)
Selects a WorkItem. ItemName is a String that specifies the WorkItem to select.
SetText (Text)
Enters text in the text box. Text is a String that specifies the text to enter.
ShowButtonToolTip (ButtonName)
Displays the tooltip for the button. ButtonName is a String that specifies the RepositoryName of the button.
This event is significant because the CommunicationsToolbar tooltip is dynamic, causing a round-trip to the server.
Methods
The following methods are available from the SiebCommunicationsToolbar object:
For a description of these methods, see SiebCommunicationsToolbar Methods.
Properties
The SiebCommunicationsToolbar object has the following properties.
Property Name
Type
Description
ClassName = "SiebCommunicationsToolbar"
Const String
See Common Test Automation Object Properties for a description of this property.
CurrentWorkItem
String
Indicates the currently selected work item.
IsEnabled
Boolean
IsVisible
Boolean
Indicates whether or not the object is enabled.
You can not checkpoint this property because the control is not rendered by the browser when it is not visible. However, you can manually write script code to check the property.
MediaType
String
Indicates the type of media.
Message
String
The communication channel information displayed next to the Siebel menu that indicates where the message comes from (for example, Call Display).
RepositoryName = "SiebCommunicationsToolbar"
Const String
Text
String
UIName = "CommunicationsToolbar"
Const String
WorkItemDuration
String
Indicates the duration of the currently selected work item.
