Testing Siebel Business Applications > Functional Test Object Reference >
SiebTaskAssistant Object
The SiebTaskAssistant object provides methods and properties that allow you to manipulate the task assistant in a test automation environment. Parent
The SiebTaskAssistant object is a child of the SiebApplication Object. Type
The SiebTaskAssistant object is one of the Custom Control Objects. Events
The SiebTaskAssistant object has the following events.
Close |
Closes the task list. |
Done |
Clicks the Return To link. |
Next |
Clicks the See additional steps link. |
Start (TaskId) |
Clicks the link of the specified task to start a task. TaskId is a String that indicates the id of the task to start. |
Step (StepNum) |
Clicks the specified step. StepNum is a String that indicates the number of the step. |
StepView (StepNum) |
Clicks the View link for the specified step. StepNum is a String that indicates the number of the step. |
Methods
There are no methods available from the SiebTaskAssistant object. Properties
The SiebTaskAssistant object has the following properties.
ActiveStep |
String |
Indicates the number of the current step. |
ActiveTask |
String |
Indicates the id of the current task. |
ClassName = "SiebTaskAssistant" |
Const String |
See Common Test Automation Object Properties for a description of this property. |
RepositoryName = "SiebTaskAssistant" |
Const String |
StepCount |
String |
Indicates the number of visible steps. |
TaskCount |
String |
Indicates the number of tasks in the current list. |
TaskId |
String |
Indicates the name of the current task. |
UIName = "TaskAssistant" |
Const String |
