Testing Siebel Business Applications > Functional Test Object Reference > SiebCurrency ObjectThe SiebCurrency object provides methods and properties that allow you to manipulate a currency calculator in a test automation environment. ParentThe SiebCurrency object is a child of the SiebApplet Object and the SiebList Object. TypeThe SiebCurrency object is a container object that is one of the Complex Control Objects. EventsThe SiebCurrency object has the following events. MethodsThe following methods are available from the SiebCurrency object: For a description of these methods, see SiebCurrency Methods. PropertiesThe SiebCurrency object has the following properties.
| Testing Siebel Business Applications |
