Upgrade Guide > Upgrading the Siebel Database > Changing the Siebel Database Server Configuration Utilities LanguageUpgrades: All Siebel upgrades. Environments: Development, production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. The Database Server Configuration Utilities launches in the language selected when you ran the Siebel Enterprise System Installer. You can change the language in which the Utility runs, if desired, from the language chosen during installation. To change the Database Server Configuration Utilities language, see the Siebel Installation Guide for the operating system you are using. If you want an additional language to appear in the language list in the Database Server Configuration Utilities, you first need to install the appropriate language pack on the database server and on the Siebel Server. For information about installing additional language packs, see the Siebel Installation Guide for the operating system you are using. For more information about the Database Server Configuration Utilities, see About the Siebel Database Server Configuration Utilities. |
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
