Upgrade Guide > How to Perform a Siebel Database Upgrade >
Process of Planning a Siebel Database Upgrade
Upgrades: All Siebel upgrades. Environments: Development, production test, production. This process is part of a road map. See Road Map for Performing a Siebel Database Upgrade. To plan the upgrade, read the following:
- How the Siebel Database Upgrade Works.
- Siebel Database and UI Upgrade Planning.
- If you are planning to migrate to Unicode, see About Siebel Unicode Support.
- Application Planning for a Siebel Upgrade.
- Tables Modified or Seeded During a Siebel Upgrade
- Siebel Marketing Upgrade Reference
Remote Upgrade Planning
See the following resources to deploy the upgrade to remote users:
- Use Siebel Packager to create language packs for remote installation. See Going Live with Siebel Business Applications.
- Use Siebel Anywhere to create installation kits for deployment. See Siebel Anywhere Administration Guide.
- Generate a Siebel Remote database template. See Siebel Remote and Replication Manager Administration Guide.
- Set up database extraction for Mobile Web Clients. See Siebel Remote and Replication Manager Administration Guide.
